HotSpot + PPPoE Server
Hi friend, I have a little problem, i want to activate PPPoE server and hotspot in the same interface wlan1.
I have setup hotspot and pppoe server and its work perfectly but one at time. In effect to work whit pppoe server i must set ether1 (to adsl) ARP= proxy-arp, instead to work whit hotspot i must set ether1 to ARP= enabled. There is a way to work whit hotspot and pppoe server togheter ???
Tnk u
Hi There,
I have multiple sites running PPPoE and Hotspot. I have both services enabled to the same bridge interface. PPPoE has a public IP pool and the Hotspot is masqueraded behind the routers address. I use external RADIUS for both and have seen up to ~50 users online between the two services.
I didn’t have to do anything different to what I would do if i was just configuring PPPoE or Hotspot individually.
