Hi guys.
I’m create a hotspot with Mikrotik router 3011, Android devices work fine but with IOS device after turn off screen for awhile (20-30s) wifi will auto disconnect and i have to reconnect to use internet.
Is there anyone have the same problem?
I have searched some topic in forum but do not find any solution yet =/
Is there anyone know this issue, please help ? ![]()
Good Morning,
I have the same problem with a 1100AHx4.
With android and windows client work well, but the client always show no internet connection (is not a problem because this device surf internet correctly).
The apple client don’t connect to wifi network (problably for negative check internet) or when are connected don’t show the login page automatically, if i type manually the addres of the router it’s work.
Can you help me ?
So if WiFi disconnects, why is the title “hotspot problem”?
I think that this should be asked to Apple Forum not Mikrotik! When Mikrotik works with all Android and Windows, ask Apple how their system process the packets in idle mode!
See this thread http://forum.mikrotik.com/t/mikrotik-wi-fi-and-iphone-problem/107509/1
Maybe will be usefull
I have the same problem. Is there anyone know this issue?
