Hotspot problem
Dears,
I have a RB411 inside of RIC/522 , i want to install hotspot on it , but when i install hotpost every thing going to work fine but i can’t login into the hotspot more than 1 user. i mean only one user can log to hotspot. other users when they want to log in the page says: you license not allowed to login.
the level of the router is 3.
please let me know if any one now this problem , shall i upgrade my RouterOS or i have to purchase another level or license.
Thanks,
Twana
HI twana222
I think you need higher license on the Router OS ..
Here the Specifications for license
Packages required: hotspot, dhcp(optional)
License required: Level1 (Limited to 1 active user) , Level3 (Limited to 1 active user) , Level4 (Limited to 200 active users) , Level5 (Limited to 500 active users) , Level6
Submenu level: /ip hotspot
Standards and Technologies: ICMP, DHCP
Hardware usage: Not significant
More to learn about the HotSpot check this link. http://www.mikrotik.com/testdocs/ros/3.0/pnp/hotspot.php
