Im expiriencing hotspot slowdown after few hours of working. I tryed all kind of setups, but always the same. What could i miss with the wizard?
Is there any other trick? What could slow down responding, resolving pages?
Uploads, downloads, msn, internet radio, all work great, showing pages is the dificult part? Please help. My costumers are all pised, i cant stand the preasure, i need the formula to solve my stupid problem.
PC is athlon 1700+ with 256Mb DDR, 1 lan card and 1 wireless card. Hotspot setup is just basic with hotspot login.. (x.19 version of mikrotik and had the same problem with last 5 versions)
“Error: 504 Gateway Timeout” is what i get after hotspot is 4 hours online..
Slow responding or no responding while surfing.
Connecting to MT via winbox is fast, without problem.
Please help.
Try to check the connection doing ping to the mikrotik with large packets, in windows try the commmand “ping 192.168.10.1 -l 1500 -t”(replace 192.168.10.1 with the IP of your router)
Are you using webproxy? is in mode transparent?
Share more info…
