Hotspot Problem
I have setup a new hotspot and it works for one user. When a second user attempts to connect the browser appears to loop at the redirect page. Per suggestions found in other areas of the forum I have done the following:
  1. Removed the Address Pool from Servers
  2. Removed DNS name from Server Profile
  3. Checked HTTP CHAP and PAP on login.
Any idea, any help would be greatly appreciated.
ip hotspot server, select the hotspot and click RESET HTML.
Ok. I did as you suggested. I had to replace my coding within the HTML files. I am still having the same issue. Could it be the coding for redirect?
Sample code from login.html:
_
_
_
_
