dorijan
1
I am using hotspot with freeradius server, and I got problem when I try to authenticate.
Here is what I got on log in mikrotik
13:36:41 hotspot,error,info,debug xxxx@xxx.com (10.1.2.254): configuration error: login failed: failed to add route
<xxxx@xxx.com>: bad prefix
On radius server I see that autentification is ok, accept is send, and in mikrotik radius status monitoring, i see that accept is increased…
Any suggetions would help
Eugene
2
What version are you using? What attributes your RADIUS server is sending back to the router?
dorijan
3
freeradius_1.1.1-0_i386.deb
how can I see what I got back…
this is what I got on freeradius -x
Sending Access-Accept of id 28 to 161.53.xx.xx
Framed-Route = “xxxxxxx@xxx.com”
Configuration-Token = “student”
Connect-Info = “NONE”
bjohns
4
Framed-Route should be an IP Address.
