I’m having some issues with HotSpot using 2.9.46 version.
First o all, it seems that sometimes HotSpot service crash, because nobody can log (the login page does not appear), and although I put the client in IP Bindings, the client can’t navigate. I have to reboot when this happend.
Second, I have recive recently the following log message:
“login failed: no chap for for http-chap login method”
firstly are you using an ssl cert and are you using a static dns entry?
if so, try removing the “dns name” under server profiles and get a user to re-attempt login.
If still no luck, make sure your ssl is set to “cert1” or whatever certificate you have installed.
