Hotspot+proxy+load balancing
Hello ,
Starnge problem
I have a router that work as load balancing , also install on it hotspot - working gust great
now I have try to install on it proxy to be able to block some websites on the hotspot
this is where my problem start
I can login the system - but I can’t surf on the browser
I can ping to all sites , I can use whtsup - all is working - also the websites that are in my “block” list in the proxy.
if I disable all the mangle rules for the load balancing -
the proxy start to work , it block me the websites -
so what is wrong?
can’t I run proxy with load balancing?
Thanks ,
