Hi
I’d like to know if is there a way to bypass some IPs to the Hotspot Authentication Proxy.
Because here in Brazil we have a program that uses the 80 port and it cannot be proxied.
I’ve tried to change the hotspot firewall rule to bypass these IPs, but it is dynamic and doens’t work
Walled-Garden wouldn’t work cause it’s another proxy, isn’t it?
You can specify proxy for HotSpot requests,
‘ip hotspot profile set profile_name http-proxy’.
As well you can setup aparent proxy on the HotSpot router and manage it from ‘proxy’ menu in RouterOS.
That’s the matter, I don’t want to specify a proxy for the users (these options are disabled)
I’m having problems with the Hotspot Authentication Proxy (all traffic pass through this proxy), that uses the 64872 port, so the program won’t work because this.
