The problem is that I have a few IP to share among multiple routers and interfaces, and I don’t want to assign the routers statically because i’d be fragmenting the range and wasting public IP.
To solve fragmentation, could hotspot create a dynamic route to a client whenever it gives him a public IP (instead of having me to create the route)?
And could that route be shared with OSPF?
This has disadvantage that you don’t know which user is mapped to which address, so you can’t track users.
I planned to use RADIUS and sqlippool, but when I simulated this using Framed-IP-Address in reply, I got mapping in /ip hotspot host, but it did’t work because of routes. I configured OSPF, but the route was not created in the contrary of PPPoE users where this works perfectly.
So, what is the best way to distribute public IP’s to all hotspot users (we’ve got /20 range of IP’s). Shell we just subnet and assign new IP pool to each hotspot or do something better and not waste many public IP’s.
Doing HotSPot Setup with private series of IPv4 address (eg. 10.5.50./23 . Default Pool of MT HotSpot). This would automatically create DHCP server of this Network and hosts on HotSpot interface will be assigned IP from this pool. You can observe connected/assigned address hosts in IP->>HostSpot->>Hosts. Over there it would shows something like --MAC address-- Address-- to Address. Eg. xx:xx:xx:xx:xx:xx – 10.5.50.21 – 10.5.50.21
The trick here will be Radius server, wherein the users profile would be to allow login from selected pool (in your case 222.22.22.0/24). As the auth request of the user is send to the Radius (Access-Request), if validated Radius would response with Framed-IP (eg 222.22.22.23 - ie any Random IP) in Access-Accept.
This would then change the “To Address - 222.22.22.23” which can be observed in like
Eg. xx:xx:xx:xx:xx:xx – 10.5.50.21 – 222.22.22.23
In this way you’ll have Public IPs assigned only to logged in users, and hence no wastage of Public IPs.
I have the same problem, I have multi hotspot server that I wan’t give ip public to all authenticated users from share public pool IP,. I mean I don’t want to waste public IP.
