HotSpot RADIUS authenication
I am trying to configure a HotSpot with RADIUS auth om Mtik 2.9.2, and I have few problems. :confused:
I have router with 5 ethernet ports. One is connected to ADSL, one to local network, and one I would like to configure as HotSpot. Planet wireless AP is connected to the ether3 and HS is configured but it works only if user is configured localy (on the router). At the same time VPN auth wia RADIUS works fine, and users can connect and authenticate with IAS. I have tryed everything I could find on the subject, but it still does not work.
What am I doing wrong.
Best regards
Hi Satman1w
1st off, upgrade your router to 2.9.44 there have been many fixes / changes - some will probably help you
