Someone can give me an idea of how can i get all this working?
i have a dedicated link and a adsl, i want that all the traffic for the radius server just out from the dedicated link, cause the radius is on another city, ive tryed mark-routing but didnt work.
In this case, its better use ECMP to load balance or anyone has another suggestion?
ah im using mkt 3.10
Well, just a simple traffic from http, out for my adsl link, doest work, or im doing all wrong, or theres something else
OBS: I know the rules are disabled, i did just to illustrate how im doing my configs.
/ ip firewall mangle
0 X chain=prerouting action=mark-routing new-routing-mark=http passthrough=yes
src-address=10.0.0.0/24 dst-port=80 protocol=tcp
0 D chain=dstnat action=jump jump-target=hotspot hotspot=from-client
1 I chain=hotspot action=jump jump-target=pre-hotspot
2 D chain=hotspot action=redirect to-ports=64872 dst-port=53 protocol=udp
3 D chain=hotspot action=redirect to-ports=64872 dst-port=53 protocol=tcp
4 D chain=hotspot action=redirect to-ports=64873 hotspot=local-dst dst-port=80 protocol=tcp
5 D chain=hotspot action=redirect to-ports=64875 hotspot=local-dst dst-port=443 protocol=tcp
6 D chain=hotspot action=jump jump-target=hs-unauth hotspot=!auth protocol=tcp
7 D chain=hotspot action=jump jump-target=hs-auth hotspot=auth protocol=tcp
8 D chain=hs-unauth action=return dst-address=201.xxx.xxx.xxx
9 D chain=hs-unauth action=return dst-address=10.0.0.1
10 D chain=hs-unauth action=return dst-address=200.xxx.xxx.xxx
11 D chain=hs-unauth action=redirect to-ports=64874 dst-port=80 protocol=tcp
12 D chain=hs-unauth action=redirect to-ports=64874 dst-port=3128 protocol=tcp
13 D chain=hs-unauth action=redirect to-ports=64874 dst-port=8080 protocol=tcp
14 D chain=hs-unauth action=redirect to-ports=64875 dst-port=443 protocol=tcp
15 I chain=hs-unauth action=jump jump-target=hs-smtp dst-port=25 protocol=tcp
16 D chain=hs-auth action=redirect to-ports=64874 hotspot=http protocol=tcp
17 I chain=hs-auth action=jump jump-target=hs-smtp dst-port=25 protocol=tcp
18 X ;;; place hotspot rules here
chain=unused-hs-chain action=passthrough
19 ;;; masquerade hotspot network
chain=srcnat action=masquerade src-address=10.0.0.0/24
/ ip route
DST-ADDRESS PREF-SRC GATEWAY-STATE GATEWAY DISTANCE INTERFACE
0 A S 0.0.0.0/0 reachable 200.xxx.xxx.xxx 1 bridge1
1 X S 0.0.0.0/0 192.168.254.254 1
2 ADC 10.0.0.0/24 10.0.0.1 0 AP
3 ADC 192.168.254.0/24 192.168.254.2 0 ether1
4 ADC 200.199.117.72/29 200.xxx.xxx.xxx 0 bridge1
