Hello, i am new with mikrotik hotspot and I have a problem with de radius database for hotspot user. When I trie modify parameters on database it returned with the following error: Radius server not responding.
Please help me
Please help me
What parameters do you modify?
Do you have RADIUS server working correctly, before these changes are applied?
Same problem for me
There are several places needed to configure.
In RB:
Radius section should be configured.
IP/ Hotspot/ server profile/ radius tab should be configure
In UM:
Routers - you should create your router and try to config it.
If you of above has done correctly so there should be no error and no problem.
Usermanager a RADIUS server responds to the interface from which came the authentication request. In a network in which there are multiple paths from hotspot to RADIUS server must configure hotspot the addresses of all the interfaces that are under consideration.
Example of setting hotspot, when RB with usermanager on network with dynamic routing has three interface used by way from hotspot:
/radius
add address=192.168.255.145 secret=1234567890 service=hotspot
add address=192.168.255.132 secret=1234597890 service=hotspot
add address=192.168.255.113 secret=1234597890 service=hotspot
i want to show Download limit and how much the user have consumed from this limit on status page
i have tried to use all the available variables but all gave no value
i think it is because the limit is set within the userman radius not with the hotspot
but how can i show the userman download limit and the download used within the status page
You should not claim your problem here my friend ![]()
http://forum.mikrotik.com/t/help-needed-to-show-download-limit-and-used-bandwidth-in-status/86139/1
above link should help. maybe
please help me out…did my hotspot configs with radius…everytime i try to login is displays radius server not responding…
