HotSpot - Radius profiles
Why my hotspot dont use profiles from radius server. It using only profile from user profiles i have ROS 5.4.
Sorry for my english.
/ip hotspot profile set [find name=<profilename>] use-radius=yes
To select the hotspot user profile, return
attribute=“Mikrotik-Group” value=“profilename”
from the radius server on Access-Accept.
See if it is being returned. Set radius logging.
/system logging
add topics=radius,debug action=memory
Try to login and then check the log.
The profile name must exist in “/ip hotspot user profile” or you will get a “configuration error” on the login page.
Thx for help. It is working.
plz can u tell me the how to add attribute=“Mikrotik-Group” to Microsoft windows server 2012 radius ??
