Hotspot Radius Support
Hi all,
I have tried to find some features that offered by radius to hotspot..
However i can’t find enough information either from forms or documents..
The ROS 2.9 documents (http://www.mikrotik.com/docs/ros/2.9/guide/aaa_radius)
said Radius Rate-Limit Attributes only used with ppp.
But Hostspot manager (http://www.mikrotik.com/hotspot.html) page point that
you can set Upload and Download Rate.. As i understand with this page
Hotspotmanager use radius. So it must provide this feature with radius attribute. Isn’t it?
If its support which Attribute or Attributes are make trafic rate limiting?
Also when i searched forums i met some discussion that to related to this issue.
And one of the answer said Rate-Limit feature supported all other radius clients(hotspot vsvs) with Mikrotik OS 2.9. Is this correct?
Could you give me some reference point to solve this problem..
Regards
devrim
rate-limit should be usable also for hotspot.
the manual does not say that it is for PPP only anymore :slight_smile:
Himm,
Yes by now you are right.. May be i read old documents!
Thanks for your respose..
Regards
devrim
