[Hotspot] Redirect new devices on external website, cut connection if skipped
I’ve been smashing my head on this for a few days now. I want to set up a page that people redirect after they login on the hotspot and if they skip it their connection is cut off. I was looking into advertising for this, maybe try to get the page to pop in only once but no luck. Then I changed the status screen to do that job which leads to the next problem. Almost everyone with android uses the pop-up to redict to the login page and after they log in, it closes automatically, skipping the status splash screen. I want a setting or script that if the page is not visited for x seconds to cut the connection.
Redirect to your page first and have the login on it (or a link to a separate login page.) This way both android and ios devices will see your advertisements.
