Before I start… I have searched the forum for the answer but no topic about hotspot solved my problem so I have to start a new one.
I am pretty new in hotspot but I have managed to make something that may work. Partially work… The thing is that I need hotspot where users don’t need to add any kind of username or password, it will login automatically. So, user connects to the network, opens the browser and there is a login page which has predefined user/pass and it will login automatically but I would like the user click somewhere and then auto login activates.
Second thing is alogin.html page. It is displayed only if I use cookie login in server settings and it doesnt redirect me to the predefined page. Only shows that the user is successfully loged in. I followed instructions from this topic http://forum.mikrotik.com/t/no-login-page-hotspot/46560/1
Next… If I disable cookie login then I see status page every time after login. This is what I would like to avoid.
BTW, Is it possible to redesign those pages and add custom photos?
All is possible
Our system use responsive web pages, like this:
As you can see, you login with just ACCEPT button, or by typing your e-mail, or… by login with your social accout in facebook, google, twitter etc.
Thanks for reply, friend. Is this powered by mikrotik?
I need login page which will say for example “To login, please click here”. No usernames and passwords. user/pass can be predefined or automatically generated. after this I need redirection to some webpage… for example http://www.yahoo.com.
The only thing missing here is how to do it. Like I said… I am pretty new in hotspots.
You can just create a html page, where you have a , with login, password and submit button. You can write login name inside that file, and let the user to type only the password. If you don’t know how to send variables from MT to external PHP, just enable HTTP-PAP in hotspot server profile. Of course it’s less secure, but it’s easier for a start.
Thanks friend. This is going to be free wifi internet but I want to limit users by bandwidth and time. They should stay connected for about 2 hours and after that they will need to login again. So, I dont need user type anything. All I need is this:
User connects to wifi
User opens the browser and custom login page is displayed with welcome screen saying: “To login click the photo”
After successful login user will be redirected to some webpage . http://www.facebook.com for example.
This is more HTML and web programming and I am not familiar too much eith it. Is there a simple way to do what I described above?
I can understand you, but you asking to much if you expecting that someone will do that job for you.
No there isn’t any simple way. There is only one right way to do that: start reading and trying to do that.
You can buy “know how”, or try to do this by yourself. You have all the puzzles above, and all is described in wiki.
Respect our time and ask specific questions as you hit a problem.
Yes, I do respect Your time and apreciate every single reply posted in order to help. I just thought that there are some templates, easy to edit or similar… Yes, I read but it’s not that fast and I have time limits to make it really work so I bought “know how”. Hehe… 30 EUR and all problems with HTML are past now.
As for real problems… may not a problem but it is a question. Is it possible to have autogenerated passwords for every user when clicked on login? Autologin after that…
It’s possible, if you are using external authentication server. You can redirect to external server, and make every user unique account based on MAC addres. You can take MAC from MT-hotspot (it’s one of the variables in session). If you have a MAC, you can generate password and put it in Radius database, and on the end generate a html-link with specific login and password.
