hotspot relogin problem
I have setup mikrotik in hotspot mode with radius authentication by mac. Login goes ok, but if I remove an user, this user can’t log in again. I must disable and enable de hotspot so the user can login again.
Is this a bug, or I have missed something in the config?
Version 2.9.7
The radius works ok, I have similars deployment with vers. 2.8 and work nice.
If you remove the user manually make sure you remove he mac from the ‘Hosts’ section (Tab) too.
You should upgrade to 2.9.11 too, it´s better than 2.9.7
Oopps. That do the trick. After looking in almost all conf parameter, if I remove in Active AND Hosts tab the user log in ok again.
Thanks!
