This config is working exactly how I want however any http/https requests timeout ONLY on the hotspot network W6SG.
If I turn off the hostpot server, it works. Ping to the outside always works, just not http.. What am I doing wrong?
# oct/17/2016 15:50:26 by RouterOS 6.36.2
# software id = FVQV-GHU4
add admin-mac=4C:5E:0C:F9:B9:21 auto-mac=no comment=defconf name=MARS-Bridge
add name=W6SG-Bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
disabled=no distance=indoors frequency=auto mode=ap-bridge name=MARS-wifi \
ssid=MARS wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether4 ] master-port=ether2-master
/ip neighbor discovery
set ether1 discover=no
set MARS-Bridge comment=defconf
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" \
group-ciphers=tkip mode=dynamic-keys unicast-ciphers=tkip \
wpa-pre-shared-key=dougdoug wpa2-pre-shared-key=otla27otla27
add authentication-types=wpa-psk,wpa2-psk eap-methods="" \
management-protection=allowed name=OPEN supplicant-identity=""
/interface wireless
add disabled=no keepalive-frames=disabled mac-address=4E:5E:0C:F9:B9:24 \
master-interface=MARS-wifi multicast-buffering=disabled name=W6SG-wifi \
security-profile=OPEN ssid=W6SG wds-cost-range=0 wds-default-cost=0 \
wps-mode=disabled
/ip hotspot profile
set [ find default=yes ] login-by=cookie,http-pap
add name=192-pool ranges=192.168.88.10-192.168.88.254
add name=172-pool ranges=172.16.10.10-172.16.10.254
add address-pool=192-pool disabled=no interface=MARS-Bridge name=MARS-DHCP
add address-pool=172-pool disabled=no interface=W6SG-Bridge name=W6SG-DHCP
/ip hotspot
add address-pool=172-pool disabled=no idle-timeout=none interface=W6SG-Bridge \
name=server1
/ip hotspot user profile
set [ find default=yes ] address-pool=172-pool
add bridge=MARS-Bridge interface=ether2-master
add bridge=MARS-Bridge interface=MARS-wifi
add bridge=W6SG-Bridge interface=W6SG-wifi
add address=192.168.88.1/24 comment="MARS Network" interface=MARS-Bridge \
network=192.168.88.0
add address=172.16.10.1/24 comment="W6SG Public Network" interface=\
W6SG-Bridge network=172.16.10.0
add address=192.168.1.20/24 comment="modem maint net" interface=ether1 \
network=192.168.1.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
ether1
/ip dhcp-server lease
add address=192.168.88.236 client-id=1:0:26:ab:d0:84:3d comment=\
"Epson Workforce 435" mac-address=00:26:AB:D0:84:3D server=MARS-DHCP
add address=172.16.10.0/24 comment=172 dns-server=\
8.8.4.4,4.2.2.1,8.8.8.8,4.2.2.2 gateway=172.16.10.1
add address=192.168.88.0/24 comment=defconf dns-server=\
8.8.4.4,4.2.2.1,8.8.8.8,4.2.2.2 gateway=192.168.88.1
set servers=8.8.4.4,4.2.2.2,8.8.8.8,4.2.2.1
/ip dns static
add address=192.168.88.1 name=router
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here" disabled=yes
add action=accept chain=input comment="defconf: accept established,related" \
add action=drop chain=input comment="defconf: drop all from WAN" \
in-interface=ether1
add action=accept chain=forward comment="defconf: accept established,related" \
connection-state=invalid
connection-state=new in-interface=ether1
add action=drop chain=forward disabled=yes dst-address=192.168.88.0/24 \
src-address=172.16.10.0/24
add action=drop chain=forward disabled=yes dst-address=172.16.10.0/24 \
src-address=192.168.88.0/24
add action=drop chain=forward in-interface=MARS-Bridge out-interface=\
W6SG-Bridge
add action=drop chain=forward in-interface=W6SG-Bridge out-interface=\
MARS-Bridge
out-interface=ether1 src-address=192.168.88.0/24
add action=masquerade chain=srcnat out-interface=ether1 src-address=\
172.16.10.0/24
/ip hotspot user
add name=w6sg-user password=1password
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
/system clock
set time-zone-name=America/Los_Angeles
/system routerboard settings
set cpu-frequency=650MHz protected-routerboot=disabled
/system scheduler
add interval=1d name=W6SG-close on-event="/interface wireless disable wlan2" \
policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive \
start-date=sep/08/2016 start-time=22:00:00
add interval=1d name=W6SG-open on-event="/interface wireless enable wlan2" \
start-date=sep/08/2016 start-time=10:00:00
/tool mac-server
add interface=MARS-Bridge
/tool mac-server mac-winbox
