I have set up a RB532 as a hotspot on the wireless interface, but would like to secure it. I don’t want users of the hotspot to be able to access the routerboard via Winbox. How would I go about doing this? Would I create a NAT rule?
(the eth1 interface will have a separate network that will make use of the web proxy but not the hotspot)
If I am creating an address pool eg. 192.168.99.0/24 for use on the hotspot. Can I not just create a firewall input rule to drop all input packets from this range of IPs?
/ip firewall filter add chain=input src-address=192.168.1.2(change to yours) dst-address=192.168.1.1(change to yours) action=accept comment=“allow specify login” disabled=no
disable port 8291 if you add for accept with out interface selected
