What does mean by Address by Mac & why it’s mentioned 2?
Clarify us. kindly find the attachment too!!!
It relates to the number of IP addresses allowed per MAC address. 2 is the default I believe
First of all thanks for your reply.
Which means one mac address will take two IP address? It will take two IP address from my dhcp range?
kindly clarify!!!
It’s used by the hotspot to internally NAT a misconfigured client to an IP address it can deal with. Under normal usage, a guest that has the correct range for an IP address will have the same to-address as their real address.
