Hay,
I face a problem when i restart the MT all my hotspot setting gone and i have to make it again >
I try remove the package and intsall it again but same thing
Any advice please?
is there someone resetting your router??? are you checking through winbox?? try to backup your configurating first..change the password, then reboot the router and see…
