hotspot setup causes network intrupt
hi ppl
when I setup the hotspot I can’t ping anywhere on IP range that the hotspot is installed… it is very weird why this thing happens but I setup the default hotspot using wizard.
when I disabled the hotspot it wil be back to normal and I can ping MT box and also I can ping everywhere from the console. I’m using 2.9.11
thanks
because the router now is considering the interface as hotspot interface. so you have to login in ordedr to be eligibile for internet etc.
add another interface (3rd) which you will dedicate to the hotspot …
surely I have already logon to mt box that I can winbox to it over the ip but it is kinda tricky.
