Hi all,
I’m trying to setup a hotspot (second Mikrotik setup I’m doing - first is still working
), but I’m currently lost in all the possibilities.
What I’m trying to achieve:
- Port 9 and 10 → bridge-hotspot (will contain 2 ports, 1 for all hotspot users, one for admin usage)
- Port 6,7,8 → bridge-admin (will contain an ‘open’ connection to the internet – aka no hotspot).
- Port 1 → Internet - DHCP client.
As soon as I activate the hotspot which is on bridge-hotspot it stops all the flow on these ports.
I tried stripping almost everything, even no bridges (I thought this was the cause). But even that didn’t work out.
I must be overseeing something which is wrongly configured and I don’t see it (anymore).
Any help is welcome, if you need more info let me know!
Remon
# may/21/2019 21:07:03 by RouterOS 6.44.2
# model = RB4011iGS+
add admin-mac=74:4D:28:64:94:B2 auto-mac=no name=bridge-admin
add admin-mac=74:4D:28:64:94:B1 auto-mac=no name=bridge-hotspot
set [ find default-name=ether1 ] name=ether1-internet-dhcp
set [ find default-name=ether2 ] name=ether2-not-used
set [ find default-name=ether3 ] name=ether3-not-used
set [ find default-name=ether4 ] name=ether4-not-used
set [ find default-name=ether5 ] name=ether5-not-used
set [ find default-name=sfp-sfpplus1 ] disabled=yes
add name=WAN
add name=LAN-HOTSPOT
add name=LAN-ADMIN
/ip hotspot profile
set [ find default=yes ] dns-name=hotspot.nl hotspot-address=192.168.4.1 html-directory="" login-by=http-chap,mac-cookie name=hotspot-server-profile
add name=dhcp-pool-hotspot ranges=192.168.4.10-192.168.5.254
add name=ipsec-pool-local ranges=172.168.0.1-172.168.0.100
add name=ipsec-pool-remote ranges=172.168.0.101-172.168.0.200
add name=dhcp-pool-admin ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp-pool-hotspot disabled=no interface=bridge-hotspot lease-script="/system script run corinex-bypass" name=dhcp-server-hotspot
add address-pool=dhcp-pool-admin disabled=no interface=bridge-admin name=dhcp-server-admin
/ip hotspot
add address-pool=dhcp-pool-hotspot idle-timeout=none interface=bridge-hotspot name=hotspot-server
/ip hotspot user profile
set [ find default=yes ] address-pool=dhcp-pool-hotspot mac-cookie-timeout=128w4d name=5mbit-4users on-login=":log info \"Login\";" on-logout=":log info \"Logout\";" shared-users=4
add address-pool=dhcp-pool-hotspot !idle-timeout mac-cookie-timeout=142w5d name=unlimited on-login=":log info \"Login\";" on-logout=":log info \"Logout\";" shared-users=unlimited
/ppp profile
set *FFFFFFFE local-address=ipsec-pool-local remote-address=ipsec-pool-remote
add bridge=bridge-admin interface=ether6
add bridge=bridge-admin interface=ether7
add bridge=bridge-hotspot interface=ether8
add bridge=bridge-hotspot interface=ether9
add bridge=bridge-hotspot interface=ether10
/interface bridge settings
set use-ip-firewall=yes
set discover-interface-list=LAN-ADMIN
add interface=bridge-hotspot list=LAN-HOTSPOT
add interface=ether1-internet-dhcp list=WAN
add interface=bridge-admin list=LAN-ADMIN
add address=192.168.88.1/24 interface=bridge-admin network=192.168.88.0
add address=192.168.4.1/23 interface=bridge-hotspot network=192.168.4.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=5m
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1-internet-dhcp
/ip dhcp-server alert
add disabled=no interface=bridge-hotspot on-alert=":log error \"Other DHCP Server found on hotspot network!\";"
add address=192.168.4.0/23 dns-server=1.1.1.1,8.8.8.8 domain=lan.hotspot gateway=192.168.4.1
add address=192.168.88.0/24 dns-server=1.1.1.1,8.8.8.8 domain=lan.admin gateway=192.168.88.1
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat src-address=192.168.4.0/23
/ip hotspot user
add name=remon password=somepassword server=hotspot-server
/ip hotspot walled-garden
add dst-host=www.mysite.nl
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip upnp
set show-dummy-rule=no
/ppp aaa
set accounting=no
/system clock
set time-zone-name=Europe/Amsterdam
/system identity
set name=hotspot
/system ntp client
set enabled=yes server-dns-names=pool.ntp.org
/tool mac-server
set allowed-interface-list=LAN-HOTSPOT
/tool mac-server mac-winbox
/tool romon port
add disabled=no forbid=yes interface=ether1-internet-dhcp
