Hotspot setup is not working!!!
I am using RB3011 Uias-rm ,I have setup hotspot .on one ethernet port 6.I do get the log_in page ,but when enter the username and password it just sits there and goes back to user name field. no internet connection. the port itself has connection without hotspot seup. I’m new to this device. I need some help! anyone out there who can help?
thanx
mtrouteredu
Post your current config here by using below command in terminal of routerboard
/export file=hotspot-problem
thank you. I figured it out.I tried to change the login.html file. that created the problem. It is working very well now.
thanks again,
vjp
