hi , ive just got a simple question, i need to setup a hotspot server on the router, ive got it working on the wireless but i also need to have the hotspot running on at least 2 more ethernet ports because im going to setup another wireless access point that is going to be running through the ethernet ports.
So basically, i just create a bridge, put the wlan and one or more ethernet ports onto the bridge and then setup the hotspot to use the bridge instead of say the wifi?
Okay so that worked, hotspot is setup and working nicely, one more question, there is going to be stations that dont need to connect to hotspot for internet, thhe people working there, how do i setup the hostpot so that those computers connect without hotspot, they will be going through the hotspot wireless connection aswell but the shouldnt see mikrotik hotspot login page, they should just connect as usual like to any other wifi access point.
