hotspot setup
well…i guess , from the way the posts are…i am the bigesssst mikrotik dunderhead.
here is my situation.
i want to do a hotspot setup.on a beach apartments siters.the link has to be accessible both indoors and outdoors.furthest distance from the main WAN link is 600m.av got a 15dbi omni antenna and 3 rb133 AP’s.how do i work out a setup.
remember,am green as far as mikrotiks are concerned.so a step bystep would by step guidance would be highly appreciated.
thanks all.
If you’re looking for step by step, I’d recommend you help yourself out and have a read over both the manual and some of the wiki pages.
If you need more than that then there are people you can pay to help you set one up..
people here are happy to helpout but can’t just spoonfeed you everything.
http://www.mikrotik.com/testdocs/ros/2.9/
http://wiki.mikrotik.com/
