Hotspot slowly browsing
Hi everyone,
I’ve read a lot of posts about this but didn’t found the solution.
I have a hotspot with these configurations:
[xxxxx@MikroTik] > ip hotspot print
Flags: X - disabled, I - invalid, S - HTTPS
 #   NAME            INTERFACE           ADDRESS-POOL           PROFILE           IDLE-TIMEOUT
 0   hotspot1        ether2              dhcp                   hsprof1           5m
[xxxxx@MikroTik] > ip hotspot profile  print
Flags: * - default
 0 * name="default" hotspot-address=0.0.0.0 dns-name="" html-directory=hotspot rate-limit="" http-proxy=0.0.0.0:0
     smtp-server=0.0.0.0 login-by=cookie,http-chap http-cookie-lifetime=3d split-user-domain=no use-radius=no
 1   name="hsprof1" hotspot-address=10.27.0.105 dns-name="login.hotspot.net" html-directory=hotspot rate-limit=""
     http-proxy=0.0.0.0:0 smtp-server=0.0.0.0 login-by=cookie,http-chap http-cookie-lifetime=1d split-user-domain=no
     use-radius=no
[xxxxx@MikroTik] > ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   10.27.0.105/16     10.27.0.0       ether2
 1   178.236.112.142/24 178.236.112.0   ether1
If I bypass the ip of my mobile i can navigate perfectly, but when I go through the hotspot, the navigation is really slowly. Any idea?
Pd. The user profile used haven’t rate limits.
Any suggestion?
You are not really giving much information to go on here. Do you have any rate limits applied to a new user on the hotspot (user profile)? That would be the first thing I would look at.
After that I would move onto more in depth things, such as CPU load of the router, see if there are any firewall rules that may be interfering, checking to see if you can optimize the firewall rule setups. Things like that.
