HotSpot SplashPage
Can I have 2 HotSpot with 2 separated SplashPages for each one on one Mikrotik in this case I have a RB2011 ROS 6.36
i believe you can. as long as you will run them on different interface
Sent from my SM-N910C using Tapatalk
Yes you can. Save your files in 2 different folders and upload them to them to the router. Under IP>hotspot>server profile change the HTML Directory on each of your profiles to the folder name that you uploaded.
Thank you that was the solution you got that right as long as I have the HTML file on a different folder on file and have that selected on the profile it work perfectly.
