I have some installations runing with differents mikrotiks RB951 and RB2011 and hotspot.
Hotspot Works with SSL certificats and a redirect page to http://login.yyyy.com.
Hotspot DSN Name is hotspot.yyyy.com and i have installed into mikrotik hotspot.yyyy.com certificates from an oficial
certified company. (crt and chains)
login.yyyy.com has as well SSL certificates from an oficial certified company, as you can see I redirect
from mikrotik to http://login.yyyy.com (less SSL warnings).
The problema is that with old deveces (most of the times) and with new devices (some times) when starts
de captive portal a warning SSL message apears telling that you are opening login.yyyy.com with hotspot.yyyy.com
certified that is not the same page.
It seems that because is not internet untill the user registers with username and pasword de ssl certificate can’t
be verified.
I have add to walled garden (providers of my SSL):
*.comodoca.com
*.positivessl.com
*.usertrust.com
and (other provider)
*.verisign.com
But still with this warnings.
Te big problema is that when a ssl apears then the hotspot gets like bloqued and doesn’t work properly.
Any help ?
Thank’s.
Oscar.
