Hotspot Statistics
Hello
Statistics tab for each user isn’t updating unless i reboot the MT! and even that doesn’t work sometimes.
Is that how it actually works? or is it a bug or something?!
V6.32.4
Nothing??
same here
Hello my friend
you should update your router os
then you check this problem
