actual on my hotspot on sucessfull login the status page not Popup.
how i can activat this, i need it to give the users the posibility to logout.
i dont can tell it to open “IP”/status …
some solution?
thanks
some solution?
thanks
maybe popup blocker blocks the window to appear.
you can manual open it by typing the ip address of hotspot. like 10.5.50.1
its not posilble a oder solution?
use the DNS Name you created while setting up the hotspot
using ip–>hotspot–>server profiles, open your server profile and check the DNS Name that you used. After that, just try opening that name from a hotspot client (no http:// needed) for status or dsnname/logout to immediately log out
For example, if the name is hotspot.test, then navigating to hotspot.test will popup the status page, while hotspot.test/logout will log you out
