HOTSPOT STOPPED WORKING AFTER CHANGING CARD FROM R52 TO R52H
Hello all,
I have been having this issue with my hotspot. I have setup hotspot RB433ah with R52 wlan card and it was working well. But after I changed the card to R52Hn, the hotspot stopped working. If I disable the hotspot, i can browse from the wlan without any problem, but as soon as I enable hotspot, the client will login but cannot access the net.
What is the problem with the setup.
Here are my hotspot setup
[admin@IMMACULATE HOTSPOT] /ip hotspot> export
jul/23/2011 18:48:15 by RouterOS 4.17
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot
http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap
name=default rate-limit="" smtp-server=0.0.0.0 split-user-domain=no
use-radius=no
add dns-name=login.immaculate.biz hotspot-address=193.168.30.1
html-directory=hotspot http-proxy=0.0.0.0:0 login-by=http-chap name=
hsprof1 nas-port-type=wireless-802.11 radius-accounting=yes
radius-default-domain="" radius-interim-update=received
radius-location-id="" radius-location-name="" radius-mac-format=
XX:XX:XX:XX:XX:XX rate-limit="" smtp-server=0.0.0.0 split-user-domain=no
use-radius=yes
/ip hotspot
add address-pool=dhcp_pool1 addresses-per-mac=1 disabled=no idle-timeout=30m
interface=wlan1 keepalive-timeout=none name=hotspot1 profile=hsprof1
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=
1 status-autorefresh=1m transparent-proxy=no
/ip hotspot service-port
set ftp disabled=no ports=21.
Check two things:
  1. Interface .. Did you configure your new card (AP Bridge, SSID, securtiy…)
  2. Bridge Port (add the new card to hotspot bridge)
Most likely is the second thing ..
You need to configure new hotspot on the new wireless card, it has different mac address.
hello all,
Thanks for your contributions.
Following the suggestions from serji that i should create another user using winbox. The user connected and browsed without any problem.
I went to usermanager and discovered that the rate limits for that users was very low and that made it not to browse the internet. The problem is not from changing the card. Thanks for your help.
it is working now.
