Hotspot through a specific wan
Hi everyone.
I have LAN connect to 2 ISP (ether1 and ether2), divided by ip segments.
that is to say:
192.168.10.20 to 192.168.10.50 go through WAN1 (wih mark routing “wan1”), and;
192.168.10.51 to 192.168.10.100 go through WAN1 (wih mark routing “wan2”).
i want to implement a hotspot in the virtual wireless interface, but using the second wan (WAN2), and i can’t get it yet.
I already marked the packets with in-interface and mark-routing, but nothing works.
What i should do?
Thanks and I will appreciate your help.
Create a new IP Pool with 192.168.10.51-192.168.10.100 and give it a desired name. Then, create your hotspot on the IP interface, but add the pool name you created.
Try to add a new Ip pool with a desired name and add 192.168.10.51 to 192.168.10.100 as your range. Then, add your hotspot with the Ip Interface, and then add your new pool. Thats all
Thanks for for answer reidavidinho.
But doesn’t work. Im using the hotspot setup for create the hotspot network on the virtual WLAN.
what do you mean by “add your hotspot with the Ip Interface”?
what will be the address for the hotspot?
