Hotspot traffic too slow
I have enabled hotspot service on my routerboard 532 through normal procedure but the problem is that when I authenticate throug hotspot the internet traffic is to slow comparing to that when the hotspot is disabled. The routerbard is runing os 2.9.1 and there is ubiquiti 2.4ghz mw card at installed on it and the dhcp is on. Anyone knows something about this problem ?
do u have some firewall rules in ur input chain ?
if part of the rule is to deny everything else after allowing some, u can disable it , also allow udp/53 in ur input chain.
it will be nice to see ur config…an export can help u
