HotSpot, transparent proxy and proxy server on the DMZ.
Hi there!
Let us consider the following case:
We have classic HS with web proxy transparent enabled for some profile of users.
If the user at the computer uses proxy server at his browser, and the server is our server (master proxy for web proxy in ROS1), there is some problems with HotSpot login page.
How to prevent using external proxy from user 192.168.0.12 [computer1] when opening HS login page.
Regards, C. G.
 / ip firewall nat \
\... add chain=hotspot protocol=tcp dst-port=3128 \
\... hotspot=local-dst action=redirect to-ports=64873
regards,
C. G.
