HOTSPOT ....... Trouble Shooting
Good morning ,
i have this follows configuration :
DNS
[admin@HOT SPOT] ip dns> print
            primary-dns: 192.168.0.200
          secondary-dns: 0.0.0.0
  allow-remote-requests: no
             cache-size: 2048KiB
          cache-max-ttl: 1w
             cache-used: 19KiB
DHCP
[admin@HOT SPOT] ip dhcp-server> print
 #   NAME             INTERFACE RELAY           ADDRESS-POOL LEASE-TIME ADD-ARP
 0   dhcp1            hot                       hs-pool-1    1h
Web Proxy
[admin@HOT SPOT] ip web-proxy> print
                 enabled: yes
             src-address: 0.0.0.0
                    port: 8080
                hostname: "proxy"
       transparent-proxy: yes
            parent-proxy: 192.168.0.250:5297
     cache-administrator: "webmaster"
         max-object-size: 4096KiB
             cache-drive: system
          max-cache-size: unlimited
      max-ram-cache-size: unlimited
                  status: running
      reserved-for-cache: 13447168KiB
  reserved-for-ram-cache: 2048KiB
HotSpot
[admin@HOT SPOT] ip hotspot> print
Flags: X - disabled, I - invalid, S - HTTPS
 #   NAME                           INTERFACE ADDRESS-POOL PROFILE IDLE-TIMEOUT
 0 X hs-ether1                      hot       hs-pool-1    hsprof1 5m
[admin@HOT SPOT] ip hotspot> pro
[admin@HOT SPOT] ip hotspot profile> pri
Flags: * - default
 0 * name="default"
 1   name="hsprof1" hotspot-address=10.10.10.1 dns-name="hotspot.creativelink.net"
     html-directory=hotspot rate-limit="" http-proxy=10.10.10.1:8080
     smtp-server=192.168.0.250 login-by=http-chap,http-pap
     split-user-domain=no use-radius=no
and This users Profile
[admin@HOT SPOT] ip hotspot user profile> pr
Flags: * - default
 0 * name="default" idle-timeout=none keepalive-timeout=2m
     status-autorefresh=1m shared-users=1 transparent-proxy=yes
     open-status-page=http-login advertise=no
The Problem :
when i open the explorer i should have the login page but … Nothing appear ,
i try put the webproxy IP and port ,
i open th explorer and every thing seems working login ,
but no internet connection ,
another try i disable the hotspot and open the explorer and every think work internet in working ,
please advice me what did i do wrong ,
and do i have to put the webproxy ip and port in explorer for all my hot spot clients ??
