hello all im newbie in mikrotik,
im using RB951Ui-2nD Ver. 6.29.1 for my hotspot connection, my first question is: am i able to use Ubiquiti AP’s so that my hotspot connection cover’s in long range?
like this…
like this…
Yes you can use it. Each client has to arrive with the transparent MAC on Mikrotik
sir thanks for the quick reply, you any sample code or procedure so that i have an ideas to follow
thanks..
xonivre
just set to bridge the port of your HotSpot and port your AP ,then just set the ubiquity to AP mode.
Yes, I have employed a similar setup for a customer. Just make sure on the ubiquiti link you use WDS to make it transparent.
