HOTSPOT user and SIMPLE QUEUES error
Hi Everybody:
I'm Using a Routerboard 500 to share my E1 Line to about 170 users.
I have the following configuration:
HOTSPOT
SERVERS: Login by HTTP CHAP and HTTP PAP
HOTSPOT USER POFILE
Session Time 1d 00:00:00
Idle Timeout 02:00:00
Rate Limit 384000
Shared User: 3
IP BINDIGS: 86
WALLED GARDEN: disabled
QUEUES
SIMPLE QUEUES: Automatic added by Hotspot autheticated users
INTERFACES QUEUES: hotstpot PCQ, wan PCQ
Im using about 200 Firewall Rules to IP Cameras.
Im using PCQ in order to limit bandwith per authenticated user and works fine, but after a while, when a user try to login, routerboard returns:
"INTERNAL ERROR: Login Failed: Failed to add queue: already have such name (6)"
I think the problem is that the Simple Queues Never Closes even when a user log off by Idle Time or by Log Off button
How can i terminate the Simple Queue.
Any tip will be helpful
Thanks and Reegards!
Please install this package and report back. If you still have problems then make support output file and send it to support@mikrotik.com
Hi Uldis
Sorry the package name is missed.
My system is running v2.9.27
I was using version 2.9.23 and it works ok for me but after the upgrade to 27 it became more unstable i don’t know if it is a bug or a configuration problem, i have several auto generated supout.rif files.
Thank’s in advance.
Install this package to you router, it should help you.
There’s a “Hotspot Fix” package on the main download page - I think this is what they are trying to say :slight_smile: It’s still bothering me that we aren’t having this problem… :confused:
@sergejs and teams
no, updates news by newsletter [email],..! or just hotspot crytical?
regards
Hasbullah
Hi Nesta. Im living in Argentina in a City named Catamarca. I have a RB500 too. Sorry for my very poor english.
it is a task difficult of learning to program mikrotik when the English language is not controlled. It would wish to interchange information with You You could be possible. My email is camjilr@gmail.com. Gracias (thank you)
