the problem is that when putting http://xxx.xxx.xxx.xxx/useradmin requests user and password, when entering them redirect to the page with error 501. User manager uses some particular port?
At the moment the mikrotik is behind another firewall and this only have port 80 8291 and 21 open. I need to open another?
I need to solve this problem hurry up.
User-Manager uses the same port as RouterOS web-page, check that www service is enabled on ‘ip service’ menu.
Use 'http://xxx.xxx.xxx.xxx/userman,
make sure that used address on the User Manager is accessible from the network of your PC.
helo,
i m sudhir and workng on mikrotik 2.9.39 i want to upgrade lincence software id.
actually i have mikrotik 2.9.39 and licence software-id is CAZD-JIT
I guess you need higher license level for the current router. New license should be purchased for current software-id, if you need to use another license level.
