I have a hotspot user with an Uptime-limit defined in their user. They connect via ethernet and login via MAC. It is set to 2 hours, and the counters are reset each night to give them 2 hours per day.
Here is their /ip hotspot user profile and hotspot server profile. The server=hotspot-wired uses the default server profile.
>/ip hotspot user print detail
;;; CharliesPC;server=hotspot-wired name="30:9C:23:82:70:54" password="secret" mac-address=30:9C:23:82:70:54 profile=charlie-ethernet-profile limit-uptime=2h uptime=2h bytes-in=27224917
bytes-out=1223886914 packets-in=324062 packets-out=1030056
>/ip hotspot profile print
Flags: * - default
0 * name="default" hotspot-address=192.168.88.1 dns-name="seaview2.patroller.net" html-directory=hotspot html-directory-override="" rate-limit="" http-proxy=0.0.0.0:0 smtp-server=0.0.0.0
login-by=mac,http-chap mac-auth-mode=mac-as-username mac-auth-password="secret" split-user-domain=no use-radius=no
When their limit-uptime=2h is reached they are logged off.
19:34:53 hotspot,debug hotspot-wired: dhcp host 192.168.88.249 removed: force mac login after client logged out
All good so far. Then the host tries to log back in and fails.
19:34:55 hotspot,debug hotspot-wired: new host detected 30:9C:23:82:70:54/192.168.88.249 by TCP :50838 -> 104.16.58.5:443
19:34:55 hotspot,info,debug 30:9C:23:82:70:54 (192.168.88.249): trying to log in by mac
19:34:55 hotspot,debug 30:9C:23:82:70:54 (192.168.88.249): using profile <charlie-ethernet-profile>
19:34:55 hotspot,info,debug 30:9C:23:82:70:54 (192.168.88.249): login failed: your uptime limit is reached
Still all good… but then the host is connected to the “hotspot-wired” server and is able to access the internet anyway.
19:34:55 hotspot,debug hotspot-wired: dhcp host 30:9C:23:82:70:54/192.168.88.249 added, ip 192.168.88.249
The user doesn’t show up in the /ip hotspot active list anymore, but still has a /ip dhcp-server lease and can stil access the internet.
