Hotspot user transfer limit
Using ROS 3.7
When I’ve setup a hotspot & created users with a transfer limit, the users can use more than their limit until the log off. Only then does it prevent them from loggin on, but otherwise they can use much more than their limit.
What can I setup to let them automatically logoff when they reach their limit?
Ekkas
hello,you can limit amount transfer in /ip hotspot user ,here you can add user’s and limits the transfer with:
Limits bytes in: bytes in for session(upload)
Limits bytes out. bytes out for session(download)
Limits bytes total: amount bytes for this user,when the user reach this value don’t logged in in hotspot.(you need that)
Sorry for my english,
regards,
Thanks for the reply,
I have that total set in UserManager and it works, but when user is already logged in, they can exceed that and keep on using internet until they log out. Only when they log out will it stop them from logging in again.
I need to disconnect user as soon as limit is reached.
Ekkas
