The problem occurred when a device first connect to a hotpost wifi. Since it is the first user and not yet registered, right after they connecting, they should be redirected to Hotspot login page.
Now the problem is, instead of going to hotspot login page. The user sees microsoft.com website instead and not the hotspot login page. Of course they have no internet access because they are not yet registered right.
Now, when I try to type 192.168.3.1 (hotspot network) I can access the hotspot login page and login normally then I have the internet connection with the profile based on userman i defined.
Below is my config.
[admin@MikroTik] > export
may/24/2018 06:39:03 by RouterOS 6.42.2
software id = UHJX-RK6X
model = 951G-2HnD
serial number = 642F06638E36
add admin-mac=6C:3B:6B:82:B4:14 auto-mac=no comment=defconf fast-forward=no name=bridge
add name=loopback
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce country=philippines disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=8773886 wireless-protocol=802.11
set [ find default-name=ether1 ] name=1.Internet
set [ find default-name=ether2 ] name=2.LocalMaster
set [ find default-name=ether3 ] name=3.LocalActive
set [ find default-name=ether4 ] name=4.Local
set [ find default-name=ether5 ] name=5.Hotspot
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=L@moste101 wpa2-pre-shared-key=L@moste101
/ip hotspot profile
add dns-name=hotspot.portal hotspot-address=192.168.3.1 login-by=http-chap name=hsprof1 use-radius=yes
/ip hotspot user profile
set [ find default=yes ] transparent-proxy=yes
add name=dhcp ranges=192.168.2.150-192.168.2.254
add name=hotspotpool ranges=192.168.3.11-192.168.3.254
add address-pool=dhcp authoritative=after-2sec-delay disabled=no interface=bridge name=defconf
add address-pool=hotspotpool disabled=no interface=5.Hotspot lease-time=1h name=dhcp1
/ip hotspot
add address-pool=hotspotpool disabled=no interface=5.Hotspot name=hotspot1 profile=hsprof1
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
/tool user-manager customer
set admin access=own-routers,own-users,own-profiles,own-limits,config-payment-gw password=admin123!@#
/tool user-manager profile
add name=admin name-for-users="" override-shared-users=1 owner=admin price=0 starts-at=logon validity=0s
add bridge=bridge comment=defconf interface=2.LocalMaster
add bridge=bridge interface=3.LocalActive
add bridge=bridge interface=4.Local
set discover-interface-list=discover
add interface=2.LocalMaster list=discover
add interface=3.LocalActive list=discover
add interface=4.Local list=discover
add interface=5.Hotspot list=discover
add interface=wlan1 list=discover
add interface=bridge list=discover
add interface=loopback list=discover
add interface=bridge list=mactel
add interface=bridge list=mac-winbox
add address=192.168.2.1/24 comment=defconf interface=2.LocalMaster network=192.168.2.0
add address=192.168.1.11/24 interface=1.Internet network=192.168.1.0
add address=10.10.0.1 interface=loopback network=10.10.0.1
add address=192.168.3.1/24 interface=5.Hotspot network=192.168.3.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=1.Internet
/ip dhcp-server lease
add address=192.168.2.158 client-id=1:6c:71:d9:2a:7e:15 mac-address=6C:71:D9:2A:7E:15 server=defconf
add address=192.168.2.0/24 comment=defconf gateway=192.168.2.1 netmask=24
add address=192.168.3.0/24 comment="hotspot network" gateway=192.168.3.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.2.1 name=router
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes
add action=accept chain=input comment="defconf: accept establieshed,related" connection-state=established,related
add action=drop chain=input comment="defconf: drop all from WAN" in-interface=1.Internet
add action=accept chain=forward comment="defconf: accept established,related" connection-state=established,related
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface=1.Internet
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface=1.Internet
add action=masquerade chain=srcnat comment="masquerade hotspot network" src-address=192.168.3.0/24
add chain=pre-hotspot dst-address-type=!local hotspot=auth
/ip hotspot user
add name=admin password=admin123!@#
/ip proxy
set enabled=yes
add distance=1 gateway=192.168.1.1
/radius
add address=10.10.0.1 secret=secret service=hotspot
/radius incoming
set accept=yes
/system clock
set time-zone-name=Asia/Manila
/system leds
set 0 interface=wlan1
/system ntp client
set enabled=yes server-dns-names=asia.pool.ntp.org
/system routerboard settings
set silent-boot=no
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
/tool traffic-monitor
add interface=3.LocalActive name=tmon1 threshold=0
/tool user-manager database
set db-path=user-manager
/tool user-manager router
add coa-port=1700 customer=admin disabled=no ip-address=10.10.0.1 log=auth-fail name=Mikrotik shared-secret=secret use-coa=no
/tool user-manager user
add customer=admin disabled=no password=admin123!@# shared-users=1 username=admin wireless-enc-algo=none wireless-enc-key="" wireless-psk=""
