I have a question about user-manager, after a long time of the use , when I go to maintenance I see that the use is 100% , what does it means?
also I need to know if there is away to remove sessions that have been registered a long ago.I see a thousand of them ?
For sessions you can select all, click edit on menu bar and click remove
For the use of 100% storage, from what I know, it’s auto resize, it’s not a defined size.
It’s not practical when you have thousand and thousand of lines , I can’t do that 100 times .
