hotspot users blocking a site
hello!
i recently bloked a site on my network, everything worked fine, but in the hotspot users it is accessible
my pc which directly connected to the mikrotik has no access.
how can i block it to the hotspot as well ?
here are the firewall rules
# oct/04/2019 14:00:27 by RouterOS 6.44.5
# software id = 4L42-C3TX
# model = RB941-2nD
# serial number = A1C30A560349
/ip firewall layer7-protocol
add comment="Mikrotik Block Torrent" name=layer7-bittorrent-exp regexp="^(\\x1\
    3bittorrent protocol|azver\\x01\$|get /scrape\\\?info_hash=get /announce\\\
    \?info_hash=|get /client/bitcomet/|GET /data\\\?fid=)|d1:ad2:id20:|\\x08'7\
    P\\)[RP]"
add comment=facebook name=facebook regexp="^..+\\.(facebook.com|facebook.net|f\
    bcdn.com|fbsbx.com|fbcdn.net|fb.com|tfbnw.net).*\$"
/ip firewall address-list
add address=10.10.4.2-10.10.4.255 list=Clients
add address=10.10.3.1 list=router
add address=0.0.0.0/8 comment="Self-Identification [RFC 3330]" list=Bogons
add address=10.0.0.0/8 comment="Private[RFC 1918] - CLASS A # Check if you nee\
    d this subnet before enable it" list=Bogons
add address=127.0.0.0/8 comment="Loopback [RFC 3330]" list=Bogons
add address=169.254.0.0/16 comment="Link Local [RFC 3330]" list=Bogons
add address=172.16.0.0/12 comment="Private[RFC 1918] - CLASS B # Check if you \
    need this subnet before enable it" list=Bogons
add address=192.0.2.0/24 comment="Reserved - IANA - TestNet1" list=Bogons
add address=192.88.99.0/24 comment="6to4 Relay Anycast [RFC 3068]" list=\
    Bogons
add address=198.18.0.0/15 comment="NIDB Testing" list=Bogons
add address=198.51.100.0/24 comment="Reserved - IANA - TestNet2" list=Bogons
add address=203.0.113.0/24 comment="Reserved - IANA - TestNet3" list=Bogons
add address=224.0.0.0/4 comment=\
    "MC, Class D, IANA # Check if you need this subnet before enable it" \
    list=Bogons
add action=reject chain=forward comment="block facebook" connection-mark=\
    facebook_conn protocol=tcp reject-with=tcp-reset
add action=passthrough chain=unused-hs-chain comment=\
    "place hotspot rules here" disabled=yes
add action=add-src-to-address-list address-list=Torrent-Conn \
    address-list-timeout=2m chain=forward disabled=yes in-interface=\
    bridge-hotspot layer7-protocol=layer7-bittorrent-exp src-address-list=\
    !allow-bit
    bridge-hotspot p2p=all-p2p src-address-list=!allow-bit
add action=drop chain=forward comment="kill P2P" dst-port=\
    !0-1024,8291,5900,5800,3389,14147,5222,59905 protocol=tcp \
    src-address-list="BitTorrent Users"
add action=drop chain=forward dst-port=\
    !0-1024,8291,5900,5800,3389,14147,5222,59905 protocol=udp \
add action=add-src-to-address-list address-list="BitTorrent Users" \
    address-list-timeout=none-dynamic chain=forward disabled=yes p2p=all-p2p \
    src-address-list=Clients
    address-list-timeout=none-dynamic chain=forward comment=BitTorrentUsers \
    in-interface=bridge-hotspot layer7-protocol=layer7-bittorrent-exp \
add action=drop chain=forward comment="KILL P2P" disabled=yes p2p=all-p2p
add action=drop chain=forward comment="KILL P2P" disabled=yes \
add action=add-src-to-address-list address-list=Clients address-list-timeout=\
    2m chain=forward disabled=yes p2p=all-p2p src-address-list=Clients
add action=drop chain=forward comment="KILL P2P OTHER CON" connection-mark=\
    other-con disabled=yes layer7-protocol=layer7-bittorrent-exp \
add action=accept chain=forward comment="defconf: accept established,related" \
    connection-state=invalid
add action=accept chain=input port=69 protocol=udp
add action=accept chain=forward port=69 protocol=udp
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new in-interface=ether1
add action=drop chain=forward comment="Drop to bogon list" dst-address-list=\
    Bogons
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface=ether1
/ip firewall mangle
add action=accept chain=prerouting comment=router dst-address-list=router
add action=accept chain=forward comment=DNS port=53 protocol=tcp
add action=accept chain=forward comment=DNS port=53 protocol=udp
add action=mark-connection chain=forward comment="client download" \
    in-interface=ether1 new-connection-mark=client-dw-con passthrough=yes
add action=mark-packet chain=forward comment=client-dw-pk connection-mark=\
    client-dw-con new-packet-mark=client-dw-pk passthrough=yes
add action=mark-connection chain=prerouting comment=client-up-con \
    in-interface=bridge1 new-connection-mark=client-up-con passthrough=yes
add action=mark-packet chain=prerouting comment=client-up-pk connection-mark=\
    client-up-con new-packet-mark=client-up-pk passthrough=yes
add action=mark-packet chain=forward comment=http-dw-pk new-packet-mark=\
    http-dw-pk packet-mark=client-dw-pk passthrough=no port=\
    80,443,5222,5223,5228 protocol=tcp
add action=mark-packet chain=forward comment=http-up-pk new-packet-mark=\
    http-up-pk packet-mark=client-up-pk passthrough=no port=\
add action=mark-packet chain=forward comment=p2p-dw-pk disabled=yes \
    new-packet-mark=p2p-dw-pk p2p=all-p2p packet-mark=client-dw-pk \
    passthrough=no
add action=mark-packet chain=forward comment=p2p-dw-pk layer7-protocol=\
    layer7-bittorrent-exp new-packet-mark=p2p-dw-pk packet-mark=client-dw-pk \
    passthrough=no
add action=mark-packet chain=forward comment=p2p-up-pk disabled=yes \
    new-packet-mark=p2p-up-pk p2p=all-p2p packet-mark=client-up-pk \
    passthrough=no
add action=mark-packet chain=forward comment=p2p-up-pk layer7-protocol=\
    layer7-bittorrent-exp new-packet-mark=p2p-up-pk packet-mark=client-up-pk \
    passthrough=no
add action=mark-connection chain=forward comment=other-con \
    new-connection-mark=other-con passthrough=yes
add action=mark-packet chain=forward comment=other-dw-pk new-packet-mark=\
    other-dw-pk packet-mark=client-dw-pk passthrough=no
add action=mark-packet chain=forward comment=other-up-pk new-packet-mark=\
    other-up-pk packet-mark=client-up-pk passthrough=no
add action=mark-connection chain=prerouting comment="facebook connection" \
    layer7-protocol=facebook new-connection-mark=facebook_conn passthrough=\
    yes protocol=tcp
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
    src-address=10.10.4.0/24
add action=dst-nat chain=dstnat dst-port=443 in-interface=ether1 \
    in-interface-list=all protocol=tcp to-addresses=10.10.3.231 to-ports=443
I think you can block the hotspot users to access those sites by adding them to the hotspot filtering rules: https://wiki.mikrotik.com/wiki/Manual:IP/Hotspot/Walled_Garden
Or you can add the same mangle and filter rules four output chain, so the proxied traffic will also match.
hello!
thank you for your post, unfortunately did not work.
in the mangle rule and in the filter i set in.interface bridge hotspot, but didnot work again.
it seems that i have something wrong with the code, i got back up in previous save and it worked fine
