HotSpot Users - Denied Access to my local LAN
Hi All,
From my principal router (192.168.10.4) I have only 1 ethernet cable attached to another Mikrotik router used for both HotSpot (via wlan1) and internal Lan (via ether3)
I have the following configuration:
Default bridge
  • Ether2-master connected to principal router using IP 192.168.10.1
  • Ether3 Connected to my local PC 192.168.1.5
  • wlan1 HotSpot Interface with IP 192.168.80.0
Peoples from HotSpot interface wlan1 (after HotSpot login success) can easily access also on my local lan 192.168.1.5… Now I want to avoid that connection between HostSpot and my Internal Lan so I created the following rule but it does not work
I added a rule on Input chain that drop all packet that comes from subnet 192.168.80.0/24 to 192.168.1.0/24
where am I wrong?
You used the wrong chain. Input is for traffic destined to the router itself. You should use chain=forward, as this is traffic being forwarded from one subnet to the other.
Oh, you are right. I used the wrong chain. Thank so much for your response.
I tried with you suggestion But i still see packets coming from HotSpot subnet (10.5.10.60/24) to Internal subnet (192.168.1.0/24)
Seems like that HotSpot mode, enables packet nat/forward before my rule.
Same here - did you solve this already??
Nope
Sent from my ONE A2003 using Tapatalk
