Hello guys,
So I set up a hotspot and did not put any rate limits on either the hotspot profile, nor the hotspot user profiles.
I also set up another interface to do a simple nat (home router style.. so no user auth)
Using a RB150 with RouterOS 2.9.50
Doing a speed test:
DNS servers working good.
I downloaded a large file from a site with reasonable throughput (kernel.org and mirrors).
Connected to the hotspot I had 60Kbps continuous download speed
Connected to the “simple nat” interface, and got 400Kbps continuous download speed
Connected directly to the cable modem (bypassing RB150), and got 600Kbps continuous download speed
As you can see, the hotspot seems to have a much lower throughput, but I’m uncertain what could be in the way.. could it be something like the default queues?
