Hotspot v6 reset html files bug?
Can anyone confirm a bug in ROSv6.0 at least in mipsbe and powerpc in hotspot module?
The problem is ‘reset html’ removes files but does not recreate them… Only img lv and xml (all empty) directories are created…
rb751u-2hnd the same problem, after reseting there is no files under hotspot directory..
I have this problem on rb751u-2hnd too. Reset html button deletes hotspot files\folders and only creates folders, not files.
Hey! i just upgraded to v6rc1 and bug is fixed! Thank you Mikrotik!
