HotSpot web pages.
Here we go again…
I need access to the web pages used in Hot Spot.
I had access to them (Via a work around) but now that too is gone.
I could use a button on the “File” screen that makes the Hot Spot files visable so they can be worked with..
A recomendation…
Create a hidden (Allways) folder to contain the templates.
Upon creation of a “server” copy the templates to a folder associated with that “server” (or copy an existing servers files if a copy of the server is made)
This will allow for the integrity of the “base files” and the ability to edit them as needed.
Craig
the default hotspot pages are already hidden/protected in the system by default, you need to set the “html-directory” option under the hotspot profile to copy them to a directory name of your choosing to edit.
/ ip hotspot profile
set default name=“default” hotspot-address=0.0.0.0 dns-name=“” html-directory=“dirname” rate-limit=“”
http-proxy=0.0.0.0:0 smtp-server=0.0.0.0 login-by=cookie,http-chap http-cookie-lifetime=3d
split-user-domain=no use-radius=no
then you can have at it!
