HOTSPOT WIFI AUTHENTICATION PROBLEM
Hi all,
I’m having a problem with my hotspot setup; the system work fine on it on until I added a pico-station hp nano to the signal. the pico is configured to bridge the wifi signal
no cable is connected. the PROBLEM IS the extended signal when connecting to it doesn’t prompt you for any username and password, gives you straight access to the internet.
Is the something I should do ?
Hi
Please , would you can more explanation to me about it ?
I have one Mikrotik RB2011 connecting me to the internet, the hotspot is running on the the wireless interface. the wireless internet is the one broadcasting the ssid; the pico station hp is the to extend the signal configured as a bridge. without the pico all work fine, radius is working to authenticate users; but once the extender is connected I the authentication with radius doesn’t work. even after configuring the extenter with the ip address of the mikrotik configured with radius with port 1812 and 1813.
